Multifunction DAQ
SH68-68-EP mapping discrepancy.
I have a DAQ cable type SH68-68-EP, Manufacturing P/N 184749B-02, Catalog Number 184749-02 which has 68-way connectors on each end.  I have cut this cable in two  in order to make two custom DAQ cables with the 68-connector on one end and a custom connector on the other.  I am using the file SH68-68-EP.png for the wire color to pin mapping.  I have noticed a discrepancy - the file says that pin 40 should be connected to a yellow/green wire but it is in fact connected to a brown/green wire.
This would only be noticed if you opened the cable to get to the individual wires.
Neville
(4,439 Views)
Accepted by topic author nwild
Neville,
You are right. I checked internal documentation and the pin 40 should be connected to the brown-green wire. There is an error in the SH68-68-EP.png file. Thanks for the feedback.
Regards
(4,424 Views)
last post indicated error in .png---yet appears it has not been corrected . .
is that so?
http://digital.ni.com/public.nsf/allkb/DE2D842E545DE64B86256F78006EAB1A
(4,043 Views)
This post is almost a year old. I recommend that you post a new question and refference this post so that the community can see the post and help further.
Alex D
Systems Engineer
Academic Research
(4,001 Views)
Alex D
Systems Engineer
Academic Research
(4,001 Views)
