Multifunction DAQ
SCC-FV01 sensor compatability
I have a SCC-FV01 frequency input module in a SCC-68.  I am needing to know if a Banner mini-beam SM312F sensor will work with this module.
I have received conflicting info on this, and need to know for sure before wasting anymore time.
Thanks.
(3,839 Views)
Added the spec sheet for the Banner sensor.
(3,837 Views)
Hi  ATPL,
After reading the spec sheet it is not clear to me exactly what type of signal the sensor is outputting. Is it current or voltage or frequency? If it is frequency 0-100Hz, then you should be able to use the SCC-FV01.
(3,823 Views)
The output configuration is Bipolar: One current sourcing (PNP) and one current sinking (NPN) open-collector transistor.
This is from the spec sheet.  Not being a EE, I am not sure if this output is compatable with the module we have.
(3,815 Views)
Accepted by topic author ATPL
I don't believe those signals are compatible with the SCC-FV01. Perhaps a digital module would be better suited for this application. Please feel free to contact your NI sales representative so they can assist you in choosing the best module.
(3,811 Views)
I did have a NI representative here today that helped us confirm this.
Thanks.
(3,807 Views)
