Multifunction DAQ
SCAN_Start in DAQmx
Hello? I wonder if the buffer parameter of SCAN_Start function in DAQ matches int32 *sampsPerChanRead parameter in DAQmxReadAnalogF64 function. And how the buffer parameter is converted into DAQmx code? It was an input and also output of SCAN_Start function in DAQ.
Message Edited by anarkie on 06-22-2009 12:05 PM
I'm converting DAQ to DAQmx..from Parkoz.com
(3,236 Views)
Accepted by topic author anarkie
Hello Anarkie,
Thank you for using NI support.  I think the parameter you want is the ReadArray[] parameter of the DAQmxReadAnalogF64 function.  I believe this is the most similar to the buffer parameter of the SCAN_Start function in DAQ.
(3,199 Views)
