Multifunction DAQ
SAE J2716 (SENT) Protocol
Hello FSAHMED, you have realized the same I wana do actually. Does your interface work stable? Would you sell your code - or would you give it to me for free? I need such a interface to check some sensors with Labview code.
Message 11 of 26
(4,638 Views)
THX
Message 12 of 26
(4,282 Views)
Sorry for the rather too late a reply. The code is free and stable as far as I have tested.
Message 13 of 26
(4,278 Views)
This is a late post, but if anyone else is searching for SENT related info this might be helpful.
We use any M-series DAQ (6211, ..., 6341, etc.) with counter inputs (counter Gate input specifically) set up to read pulse periods between falling edges with s/w debounce filtering. We buffer the pulse periods, then process the data per the SENT spec. Buffering allows us to grab ~1 second worth of data before processing, this way you don't need a deterministic system like the cRIO or FPGA. Works great. I cannot share the code because it belongs to the company I work for, not me, but if you have specific questions about implementation I can try to help.
Message 14 of 26
(4,169 Views)
i could need your SENT reading code, because i have a project to analyze a SENT frame. Can you send me the Code?
Best regards
Sebastian
Message 15 of 26
(4,041 Views)
Sorry, the question goes to fsahmed.
Best regards
Sebastian
Message 16 of 26
(4,039 Views)
We get our message in an array. This means every message is an element in the array.
Does anyone have in interpreter ready to decode the signal (FastChannel and SlowChannel)?
This is the most common readout:
1 status nibble + 3 data ch1 nibbles + 3data ch2 nibbles + 1 crc nible.
Kind regards
Wouter
Message 17 of 26
(3,871 Views)
Hi MLXCE,
As far as I know, there isn’t an interpreter for the SENT protocol in LabVIEW that doesn’t use the FPGA toolkit. If I were you, I’d try searching the NI Developer Community (https://decibel.ni.com/content/community/zone) and possibly the Instrument Driver Network (http://www.ni.com/downloads/instrument-drivers/) to see if there are any available resources.
Tom D.
Staff Software Engineer
NI
Message 18 of 26
(3,851 Views)
Hello Martzak,
I'm trying to get angular information from a sensor usign SENT without any FPGA or cRIO.
I have got a M-series DAQ (PCI 6250) and your solution seems to be suited to my application.
I would have some specification if possible.
How do you proceed to get the period of each part of your signal ?
Regards
Nicolas
Message 19 of 26
(3,600 Views)
Hi nicolgn,
                   I am also trying SENT protocol with sensor using DAQmx counter and facing problems.Is your problem solved?can u guide me how to do this?
Message 20 of 26
(3,164 Views)
