11-01-2005 05:10 PM
11-02-2005
09:19 AM
- last edited on
04-16-2025
03:44 PM
by
Content Cleaner
I'm not sure if this is what you're looking for or not, but here is a link to the S Series Help and User Manual. From a software stand point, programming is identical to M Series boards except there is no option to program the convert clock since S Series boards aren't multiplexed. There is still only one timing and data transfer engine so there is still only one ai/StartTrigger and you can only acquire data from one AI task at a time. This also means you can't acquire from multiple AI channels at the same time at different sampling rates. Which channels are acquired is still controlled by which channels are created and added to a task through the create channel function (e.g. DAQmxCreateAIVoltageChan). Only channels that have been created on the task will be acquired once the task is run.
11-02-2005 09:34 AM
11-03-2005
11:27 AM
- last edited on
04-16-2025
03:41 PM
by
Content Cleaner
Hi rrrnj-
In case you still need the S Series Help File for device-specific information.
