Multifunction DAQ
Run time Engine for Pocket PC
I'm tying to use a Pocket PC system with Microsoft Windows Mobile. Is there a version of the Run-Time engine that is compatible with this version of windows? i can only find a version for Windows 2000/NT/XP. Any help would be great!
(4,392 Views)
Hi Eddie,
What Run Time engine are you looking for? LabVIEW/DAQmx etc?
As you've posted on the Multifunction DAQ forum I'm assuming its the DAQ driver you are looking for?
The driver for NI Data Acquisition devices on a Windows Mobile platform is DAQmx Base, and the latest version of this is 2.2 - which you can download from our website at the following location:
http://digital.ni.com/softlib.nsf/websearch/E6533B5928FC562C862572970058C5D0
This provides a programming API which you can use in conjunction with the LabVIEW and its PDA module to create data acquisition applications to run on a PDA device. The driver download also includes the necessary files to download to the PDA.
If this isn't what you were looking for, can you post back a be a little more specific about what you are trying to do?
Regards
Hannah
NIUK & Ireland
(4,380 Views)
