Multifunction DAQ
Route cannot be satisfied
I have been reading up on this for two days and can not figure out how to make it happy.  Here is what I am trying to do and the resulting error.
I have two PXIe-6368 daq cards in a NI 1082 chassis with a 8133 controller running LV 2012 with everything up to date.
I have one counter(Ctr0) making a single pulse every 500ms or so to make a T0  or time zero pulse.  This is routed to PFI12.
I have ctr1 looking for that pulse to occur, delaying it and then outputting a delayed single pulse to PFI13.
I then use the T0 pulse to trigger the analog input channels data collection using PIF0 as an external trigger source and connecting PFI12 to PFI0 physically.   As long as I only get samples from one card I am fine and it all works.   If I try to add AI channels from the second card to the same task so they are in sync then I get the below error.  I understand that there is a routing conflict but I can not figure out what will fix it.   I need the Acq(AI) task to be synced and I need the T0 and DlyTask  tasks to run before the Acq task or there will be no triggers.
Error -89137 occurred at DAQmx Start Task.vi:2
Possible reason(s):
Specified route cannot be satisfied, because it requires resources that are currently in use by another route.
Property: RefClk.Src
Source Device: PXI1Slot2
Source Terminal: PXIe_Clk100
Required Resources in Use by
Task Name: DlyTask
Source Terminal: None
Destination Device: PXI1Slot2
Destination Terminal: RefClockInternal
Required Resources Also in Use by
Task Name: T0
Task Name: Acq
(3,762 Views)
Are you able to post a screenshot (or snippet) of your block diagram, so we can see how are you configuring the AI & counters, so on...
(3,744 Views)
Ok after much wiggling things around I was able to isolate the two bits of code.  I guess this is where I have to show how little I know about writing good code.
As said before...  If I set the channels in the AcqLoop to one or all AI channels on either card it is fine and everything runs.  If I add one or all AI channels from both cards to the task I get the above error.
(3,739 Views)
