Multifunction DAQ
Retrieve gain via function DAQmxGetAIGain
I want to retrieve the analog in channel gain value but when I call the function DAQmxGetAIGain a I get an error of "property not supported".
How is it possible to retrieve the current gain setting.
(3,046 Views)
The DAQmxGetAIGain can only be used to retrive the gain settings for SCXI channels. It is not possible to directly get the current gain for the daq board. But it is possible to read the Range of the daq board.
For more information see: Using Min/Max or High/Low to Set DAQmx Channel Gain
Met vriendelijke groet / Kind regards,
Karsten
(3,027 Views)
