Multifunction DAQ
Relative Humidity Sensor
Please recommend a relative humidity sensor that is traceable back to NIST which is capable of interfacing with NI-VISA.
Thank you.
(4,606 Views)
Unfortunately, NI cannot recommend specific companies for business reasons. However, if there is one you have in mind, we would be happy to give you information about compatibility with our software.
(4,561 Views)
GE makes several devices.
The moisture analyzers are costly but very accurate
http://www.ge-mcs.com/en/moisture-and-humidity/moisture-analyzers.html
They also make RH meters that dont cost as much
http://www.ge-mcs.com/en/moisture-and-humidity/relative-humidity-sensors.html
I used to work there years ago when the ge sensors division was a company called Panametrics.
Good luck.
Curt
(4,559 Views)
