Multifunction DAQ
Read single value within while loop
I have a setup with one output, driving a coil.
I then have two inputs: one to measure the voltage of my coil (the actual voltage) and the second to measure the voltage of a sensor mounted close to the coil.
The setup works fine to monitor both channels continuously, however, I want to monitor the second value only once every 5 seconds.
How can I go about doing this? Every 5 seconds I just want a single measurement from the second channel.
(4,591 Views)
You could just ignore the data from the second channel until your 5 seconds are up.  The Elapsed Time VI should help there.
(4,581 Views)
You haven't given us any info on your device, but I assume it's not super-fancy and can change sample rates per channel.
This article here explains what you want to do. Your device has a single clock, so you're essentially limited to (forces to match?) your highest sampling rate requirement with all channels and then down-sample from there if you don't want all of the data for some of the other channels.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(4,538 Views)
