Multifunction DAQ
Read datalog problems
The attached VI can read a datalog file fine until EOF is encountered but the STOP-Read from file no longer works. It did work prior to me including
it in an event handler combining both Read and Write to datalog VIs.
Any suggestions as to how to progress?
Run the VI EM Recorder.exe select read from file and select SignalMonitor.dat and this will display the file to a chart.
Javed
(3,441 Views)
This is just a small issue with the configuration of the Event structure.
To fix: Right click on the Event structure border. Select Edit Events handled by this case on the short cut menu. Within the dialog box remove the check from the 'lock front panel....' checkbox. Should all be good from this point on.
Let me know how you get on.
Stuart
P.S. feel free to rate my answer 😉
(3,403 Views)
Just got back from weeks holiday, nice and relaxing.
Unchecked the option and STOP now functions correctly.
Regards
Javed
(3,384 Views)
