Multifunction DAQ
RTD specification
I need to measure temperature with PT100 RTD. The RTD answers to the NFC 42330 specification.
I would know which specification I should use when I configure the virtual channel on MAX :
ITS90
DIN 43760
or IEC 60751
Thanks for your input
(2,829 Views)
I did some search on the web and found that most of the PT100 RTD's are calibrated to the standard RTD temperature vs. resistance table given in DIN 43760 standard.
Just to double check, I would visit the RTD's manufacturer webpage.
Keep up with the great work and good luck with your project.
(2,829 Views)
