Multifunction DAQ
Questions about USB-6008
I need a simple (low cost) USB DAQ
so I was thinking to get the model
NI-6008.
Can I use VB6 to program it?
NI provides (on the bundled CD), dll,
library, samples on how to
program it (with VB6)?
Thanks in advance,
Frank
(3,025 Views)
The USB-6008 is supported by both DAQmx and DAQmx Base, so you can definately use a USB-6008 with Visual Basic 6 through the DAQmx API.  Information on how to get started can be found at this link:
http://digital.ni.com/public.nsf/websearch/B22FE2B0F9C8935286256E920073DA07?OpenDocument
While the DAQmx driver is the preferred API under Windows, you may also use the DAQmx Base driver with VB 6 if you prefer.  It is slightly more work to set up however.  Instructions on how to do that can be found at the following link:
http://digital.ni.com/public.nsf/websearch/A21A013CA229A5988625703E0025A8AE?OpenDocument
(2,980 Views)
