Multifunction DAQ
Query about NI DaQ Windows base driver
Hi, I am using NI DAQ 6211 USB. I am using Windows7 os. I have to develop an application which will get voltage and current samples. I have installed NI DAQ MX device drivers for Windows. Do I also need to install NI DAQ MX run time engine also? Which DLL should I use to program my applications? Any help will be appreciated. Regards, Dinky
(2,949 Views)
Accepted by topic author DAQuser
You should have everything you need if you have the NI-DAQmx driver installed.  What programming language are you planning to use to program your 6211?
You should be ready to start programming using our API. Here is some information to get you started http://www.ni.com/white-paper/5438/en If you are using a text-based language, I would suggest reading the section "Using NI-DAQmx in Text Based Programming Environments"
-gaving
(2,938 Views)
