Multifunction DAQ
Pulse width of 1 us
I want to output a rectangular pulse with a pulse width of 1us using a multifunction DAQ board. How to find the minimum pulse width from the specifications? For example, for the PCIe-6353, the maximum update rate is 2.86 Ms/s. Is the reciprocal of that 0.35us the minimum pulse width?
Thanks.
(1,187 Views)
Accepted by topic author hota9912
Yes, that would be correct *if* you need to generate the pulse as an analog output task on an analog output channel.
If the pulse can be a digital logic level (~0V low, ~5V high), you have two other choices:
- a digital output task on a digital line.  This supports up to 10 MHz updates, thus 0.1 microsec pulse width
- a counter task outputting on a PFI terminal.  This supports pulse widths as low as 2 cycles of the 100 MHz timebase, or 0.02 microsec pulse width.
-Kevin P
(1,155 Views)
