Multifunction DAQ
Programming DAQmx with or without Measurement Studio
I am trying to figure out if I can program my NI-DAQmx devices using NI-DAQmx API for .NET or should I use Measurement Studio.
At some point in the near future I will upgrade my VB6 apps to VB.net.  Over the last couple of years I have been developing VB6 apps to support newer DAQmx hardware using the NI-DAQmx C API library.  Previously when I was using my older USB DAQPad 6020E (and other older hardware) I was using the NI-DAQ Traditional drivers.  When I was programming the NI-DAQ Traditional drivers I was using Measurement Studio 6.x (MS6) as my interface.  Having MS6 made my programming job easier which I definitely realized when I did not have ActiveX controls in VB6 to control the DAQmx devices I had to control.  I went thru the documentation when I installed DAQmx and was able to figure the processes out.  It took me a while but the processes I started with 'Traditional' I was able to duplicate with the DAQmx C API.  I have a copy of MS7.1 Standard (which I am considering upgrading) and I am trying to figure out if I want to use Measurement Studio when I start developing apps in VB.net or could I just use the API.
I am thinking that if the API for .NET is similar to my functions for C API maybe I could live without installing Measurement Studio.  I am a developer and my electronics understanding is not my primary strength so I think it takes me a while to figure stuff out that might be more apparent to someone who understands the hardware.  Having my code with Measurement Studio, and C API and having this forum I should be able to figure stuff out.
Thanks for any suggestions.
(3,849 Views)
Hey Chapashop,
The decision to utilize the GUI enhancements of MeasurementStudio or building everything in the .NET API is a personal decision on preference.  I really enjoy the use of MeasurementStudio in my programming environment, but the functionality of data acquisition can be fully utilized in either API.
David Pratt
Group Manager for Application Engineering Specialists | Automated Test
NIC
(3,819 Views)
I enjoyed having the MStudio activeX controls in VB6.  It made my development a lot easier.  I was somewhat spoiled by MSStudio for approximately 10 years of use with VB6.  When I used VB with the API functions for DAQmx it was definitely slow progress and difficult for me not knowing what I was doing.  But I resolved my issues and my apps work well.  I may dabble a little with the API and also with either my 7.1 that works with .NET or the trial of the latest version.
thanks, David
(3,816 Views)
Hey Chapashop,
Not a problem, good luck with your application development and let us know if you need anything else.
David Pratt
NIC
(3,803 Views)
