Multifunction DAQ
Problems with buffered AO in LabVIEW
Hello!
I am experiencing following problems:
When I try to run any VI that uses buffered analog output I get the following
error message:
"Error -10403 occurred at AO Buffer Config. Possible reasons:
NI-DAQ LV: The specified device does not support the requested action (the
driver recognizes the device, but the action is inappropriate for the device)."
Also, when I am trying to run LabVIEW:s DAQ channel wizard I get the following
message:
"Components of NI-DAQ were not found. The DAQ Channel Wizard requires that
you have NI-DAQ 5.0 or later installed. Please install NI-DAQ and restart
the DAQ Channel Wizard."
I have installed NI-DAQ 6.7 and I am using LabVIEW 5.0.1 in Win2000. My analog
output board is PCI-6703 and
input board PCI-6033E.
If someone can help to solve this problem, please let me know.
Thanks, Tuukka
(2,851 Views)
ootko varma että noi on yhteensopivia juttuja ton win2000:sen kans??
Tuukka Ritala wrote in message
news:39c0d82e@newsgroups.ni.com...
> Hello!
following
> error message:
device)."
following
> message:
analog
> output board is PCI-6703 and input board PCI-6033E.
> Thanks, Tuukka
(2,851 Views)
