Multifunction DAQ
Problems programing NI myDaq
I'm having problems with NI myDaq, it's shows me this error:
Error -50103 occurred at DAQmx Start Task.vi:7220008
Possible reason(s):
The specified resource is reserved. The operation could not be completed as specified.
Task Name: _unnamedTask<4C4>
I want to control a DC Motor.
(2,835 Views)
This happends, because you are tring to create a task that more than one module use, Which hardware are you using? Also it seems that you are using many DAQ assistant, I suggest you to use the LV examples
(2,783 Views)
