Multifunction DAQ
Problem with vi developed for optical encoder
Hello
Please some one help me in running the VI which i developed for optical encoder. I have attached the VI, in attachment files. I don't know whats wrong with it.
Jayaprakash.
(3,449 Views)
The reason the vi is not runnable is you do not have a default setting for each case
for each case structure, right click on the selection menu, say for case 0 , select
make this the default case
Do this for all case structure
(3,443 Views)
Now it's running , Thank you very much Dr.Imad
Jayaprakash.
(3,435 Views)
Hi Jayaprakash,
As an alternative to all those nested case statements - you might like to try this example code of mine.
The core logic of the three XOR functions is the same as that used in electronic hardware to decode digital quadrature signals into "increment" and "direction" (for digital counter inputs).
Hope this is might be of use to you.
Mark H.
P.S. I work for a company that designs and manufactures optical encoders.
(3,405 Views)
Hey, if you still check this acount, I'm an undergrad student trying to work with optical encoders and labview and would some appreciate correspondence.  Thanks!
(2,936 Views)
