06-02-2006 01:08 PM
06-02-2006 01:19 PM
06-05-2006 04:08 PM - edited 06-05-2006 04:08 PM
Message Edited by Travis G. on 06-05-2006 04:09 PM
06-06-2006 06:28 AM
06-07-2006 03:19 PM
06-08-2006 07:05 AM
06-09-2006
02:29 PM
- last edited on
07-25-2026
05:06 PM
by
Content Cleaner
Hello Nicholas,
You should be able to use that code shown in the screenshot attached to your last post with some minor modifications. Change the type of the DAQmx Write you are using to Digital > Single Channel > Single Sample > 1D Boolean (N lines). Also remove the Boolean Array to Number function, and just wire your array of booleans directly into the data input of the DAQmx Write VI. Let me know if this solves the problem.
Travis G.
Applications Engineering
06-09-2006 02:59 PM
