Multifunction DAQ
Problem with USB 6008 driver
Hello!
  I am having problems with my USB 6008, every time I restart or turn on my PC the analog input reads in MAX 10.6V, wich is not the signal i am applying to these input. So every time I turn on the PC I have to reinstall the driver in device manager and then it starts working perfectly.
I am using labview 7.1 in windows XP, with DAQmx 8.0.1 and NI488.
Thank you for your time!
Marco Talavera
(3,427 Views)
On front panel, double click on the VISA control and select your USB 6008 then click on the control again choose data operations and make current value default.  If this doesn't solve send copy of vi.
(3,423 Views)
Is not a VI problem because I am not running a VI, when I turn on the PC I always check the USB 6008 in MAX first, to see if all the I/O are working properly and in these case is not.
(3,420 Views)
Hi!
  I solved the problem by updating the DAQmx 8.0.1 to 8.8, which is the last DAQmx that supports Labview 7.1.
Thanks for your time
Marco Talavera
(3,377 Views)
