Multifunction DAQ
Problem with DAQmx 7.3
I recently installed DAQmx 7.3 on a desktop machine which previously had DAQmx 7.2 installed. My application did not run properly with 7.3 installed, so I went back to 7.2 and it worked fine again.
I did not have time to do much investigation with 7.3 installed, but briefly it seemed that the analogue channel data was not being returned and displayed properly in my GUI. Does anything work differently in 7.3 that might cause this?
It sounds wierd, but it looked as if the numerics did not update unless I clicked on them. I don't see why this would be a symptom of an aspect of DAQmx. The card is a PCI-MIO-16XE-50.
Any ideas?
Jamie Fraser
(2,672 Views)
Hi Jamie,
I have never heard of this happening before, it could have been just a bad install. You might try unistalling DAQ 7.2 first then installing 7.3.
Regards
Jon Bowers
NIUK
(2,672 Views)
