Multifunction DAQ
Problem of continuous square waveform generation
I'm developing my application in Visual C++. The NI-DAQ version is 6.9.3, the card is AT-MIO-16E, OS is windows 98.
I was running the example code: WFMsingleBufRegenerate.c, it worked well. Then I changed the data written to the buffer as follows:
int i;
iStatus = NIDAQMakeBuffer(pdBuffer, ulCount, WFM_DATA_F64);
for (i = 0; i <= 2499; i++)
pdBuffer[i] = 2.5;
pdBuffer[i+2500] = 0.0;
It was supposed to be a square wave, but I only got two pulse per period.
How to generate square wave and triangle wave by using C++?
Please help me, thanks in advance.
Yinsheng.
(2,954 Views)
Yinsheng,
The help for the NI-DAQ Example Utility Function NIDAQMakeBuffer() states the following:
"When you select the WFM_DATA_F64 type, the buffer will contain a 10-period sinewave, ranging between the values 0.00 and 4.99. This is useful for analog output waveform generation operations, where the data must be specified as "double-precision" (scaled)."
The code you have added to fill pdBuffer with a square wave only contains one period of a square wave, as opposed to 10. The help for NIDAQMakeBuffer() also states the following:
"When you select the WFM_DATA_I16 type, the buffer will contain a 10-period squarewave, alternating between the values 0 and 2047. This is useful for analog output waveform generation operations, where the each data eleme
nt must be specified as a short integer (binary)."
If you do not want to create your own buffer containing a square wave, you may want to consider the above option. The help for the NI-DAQ Example Utility Functions is available in the following location:
Start >> Programs >> National Instruments >> NI-DAQ >> NI-DAQ Examples Help >> Index >> Utility Functions
Good luck with your application.
Spencer S.
(2,954 Views)
Spencer,
Thank you very much.
I met more problems. I still used example WFMsingleBufRegenerate.C, and tried the selection of WFM_DATA_I16, but I didn't get any waveform. I was confused, in WFM_DATA_F64 type, the value between 0.00 and 4.99, in WFM_DATA_I16, the value between 0 and 2047, then how did WFM_Scale work? What is the output voltage respectively?
Then I didn't use NIDAQMakeBuffer(), and just create my own buffer containing a square wave, it was still two pulses per period, it seemed NI output the difference of two adjacent voltage, not the absolute value, am I right?
Yinsheng
(2,954 Views)
