Multifunction DAQ
Problem finding NI components in Visual Studio 2010 “Object Viewer” and “Project Add References”
I have purchased a USB6008  DAQ , installed DAQmx, checked the operation of device with MAX, and run example program “GenVoltageUpdate.2010 “  within Visual Studio 2010 without any problem.
Nevertheless I have several questions when I attempt to create my own project. Some may relate to National Instrument software, some to Microsoft VS2010 software. I am not sure?
The example program indicates that a new program using these features must contain references to “NationalInstruments.Common” and “NationalInstruments.DAQmx” as well as contain the Imports statement  “NationalInstruments.DAQmx”.
If I start VS2010, open a new project, open Object Browser, select All Components, and search NationalInstruments.DAQmx  or  NationalInstruments.Common  I find  no entries for these components. Why?
If  I click on Project > Add Reference  and select .NET tab, again I do not see NationalInstruments.DAQmx  or NationalInstruments.Common  listed. However, I see that selection by default has been “Filtered to .NET Framework 4 Client Profile”. Therefore, I selected the application properties, selected the Compile tab, clicked on Advanced Compile Options and changed the target framework from “NET Framework 4 client Profile” to simply “NET Framework 4”. Once the Add Reference .NET entries were filtered to NET 4,  I was able to see the required entries and add them to the application. So it appears that I can add references only by using Project > Add Reference only after editing the application properties.
However even after this change in the application properties, I was still not able to see the needed components while browsing All Components in Object Browser.  Neither was I able to see these components by browsing .NET Framework 4. Why?
As a workaround, I was able to define a Custom Component Set by browsing for the needed components. Having done this, I was also able to add a reference using the Object Browser tool “Add to references in Selected Project…”  Why should it be necessary to create a custom Component Set?
I should note that I am using the version of MS2010 that comes with Visual Basic Express and that perhaps the full version might work differently.  I also understand that NI has not tested much of its software with VS2010, only with VS 2008. Would you recommend using 2008 instead?
(3,330 Views)
Hi philgo,
You should be fine working with Visual Studio 2010 and Measurement Studio 2010. The questions you have appear to be related to a common problem with having the framework be the Client Profile instead of the regular .NET Framework 4 configuration. What I would recommend is when creating new projects in visual studio make sure to select a Measurement Studio template instead of any of the other given templates; it should configure things more correctly for your project. The other templates do not know to reference in the NationalInstruments references. When creating a new Measurement Studio template you have the ability to select the needed references on project creation and can continue to modify them by selecting Measurement Studio -> Add/Remove .NET Class Libraries.
Hopefully that addresses your questions!
James W.
(3,315 Views)
I should have specified that I am using VS 2010 Express. I now see on the NI support site that "Visual Studio Express Editions do not allow third-party integration, there is no support for Measurement Studio integration. This includes the project wizards, the Add/Remove Class Library Wizard, the Parameter Assistant, and the DAQ and Instrument I/O Assistants. As a result, you will need to manually add references to the Measurement Studio libraries within your projects."
I guess I can live with this.
The Measurement Studio Templates are also not available in VS 2010 Express and I see no way to define a new template more suitable to using my NI software including IMAQdx, DAQmx, and Vision Development System
(3,300 Views)
