Multifunction DAQ
Pressure Transducer w/ current output
Hello, I'm trying to figure out how to get a precise pressure coming from cole parmer transducer (68075-18). It has a 4 - 20mA current output and 0 to 100 psi range. I attached the diagram, please let me know what I'm missing. Thanks!
Message Edited by FlipTek on 11-16-2007 07:34 AM
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
Message 1 of 8
(4,324 Views)
What DAQ card are you using?
Message 2 of 8
(4,313 Views)
I'm using PCI 6024E.
Thanks for your time.
______________
KowdTek
LabVIEW 2009
Message 3 of 8
(4,310 Views)
If I remember, the 6024 only has voltage inputs. So you will need a resistor to convert the current into a voltage. For example, a 250ohm resistor will convert th 4-20mA range to a 1-5V signal. The resistor would go across the 2 inputs on your card and configure the input to differential. Set the range to 0-5 volts. The current signal leads go to both ends of the resistor. Resistor should be a precision unit of 1% tolerance or less.I am sure there are full details on this topic with the Developer Zone, short of time to look for you right now.
Hope this helps get you pointed in the right direction.
-AK2DM
Message Edited by AnalogKid2DigitalMan on 11-16-2007 09:38 AM
Message 4 of 8
(4,303 Views)
Hello, I really appreciate your help. Now I'm in business.
Thank you very much!!
______________
KowdTek
LabVIEW 2009
Message 5 of 8
(4,290 Views)
Cool!
Glad to have been of assistance!
-AK2DM
Message 6 of 8
(4,284 Views)
Hello AnalogKid,
I am using a 2 Axis parker motion controller (6K2) for my project.
I can control the movement of these 2 axes using the MOTION PLANNER to write a program.
I want to use Labview to control the movement of the 2 axis (via the parker controller 6K2) and to take measurements with hot wires.  I use RS232 for communication and Labview 6.1.
Can you help me?
Your help will be appreciated.
Thank so much in advance.
Hachimi
Message 7 of 8
(4,224 Views)
Message 8 of 8
(4,212 Views)
