Multifunction DAQ
Powerpack rating of the DAQPad6020E
The Powerpack of the DAQPad 6020E that i was using, was misplaced, and i wanted to use it urgently...so i was wondering if i can use another powerpack and if you could give me the powerrating including the amperage
(2,441 Views)
Here are the power supply specs as found on page 12 of the DAQPad-6020E Family Specifications Manual.
Power Requirement
9 to 30 VDC............................................15 W
Power available at I/O connector............+4.65 to +5.25 VDC at 1 A
Note: Power supply voltage should never go below 8.5 V, including AC ripple.
Here is a link to the manual:http://digital.ni.com/manuals.nsf/websearch/109B11F2D719E4D186256DA2007274A2?OpenDocument&node=132100_US
Bill B
(2,441 Views)
