I am currently using a DAQPad 6015, it is the 64 pin mass screw terminal version. I just recently upgraded my DAQmx from 7.3.1 to 8.7 with that it upgraded my Automation Explorer to Version 4.4 I was either at 3.1 or 4.0. I noticed when I was using the DAQ wizard to set up my channels it looked like the physically changed on the terminal block. Is this right??? I normally use Differential Channels, and would normally use Pin CH1(1,2) CH1(4,5)
CH2(7,8) CH3 (11,12) CH4(17,18) CH5 (20,21) CH6 (23,24) CH7 (26,27). I am seeing a completely different configuration. Any knowledge of this??
Chris
