Multifunction DAQ
Phoenix Combicon Connector for USB-621x
I'm trying to locate a part number(s) for the Phoenix Combicon connector on the USB-621x hardware.  The spec sheet only gives "Combicon".
I think this would work (Phoenix 1827842):  https://uk.rs-online.com/web/p/pcb-terminal-blocks/8042579
The width of the connector is very, very close to that given on the NI drawing.
But I'd appreciate any knowledge anyone may have.  Confirmation of the 3.81mm pitch would be a good start.
Many thanks, Ben.
(1,495 Views)
Hey Ben,
The 1847055 is used in the accessory kit for the USB 621x. So the 3.81 Pitch is correct.
https://uk.rs-online.com/web/p/pcb-terminal-blocks/8042289/
Best,
Jelmer
(1,431 Views)
Thanks Jelmer.
I think both of those are basically the same except the pitch of 1827842 is 3.81mm and 1847055 is 3.5mm.
But you mentioned the 3.81 pitch is correct, but 1847055 pitch is 3.5mm?  Did you mean 3.5mm is correct?
Many thanks again, Ben.
(1,420 Views)
