02-28-2006 05:58 AM
02-28-2006 06:08 AM
03-01-2006 12:14 PM
Hello Mic_Scale,
It would be nice for us to know what hardware and software you are using so that we understand the capabilities that are available.
It sounds like you know how to acquire a sample when a trigger is received. If not, please look at the shipping examples that install with the DAQ driver.
What does your motor require to move? Do you need to provide it with a DC voltage from your analog output? Or a pulse train from a counter? You could start this operation as soon as the analog input was finished.
I would use a digital output line to send out a digital signal. What sort of timing constraints do you need in your program? It would be fairly easy to setup all of this using software-timing no matter what hardware you are using.
Please post back with more information.
Laura
03-02-2006 02:39 AM
