Multifunction DAQ
PXI system (Unidentified)
I'm new in Labview, I have a DAQ card which its model is  "NI-PCI-6221(A)",
I've pluged it into the computer, but when I launch MAX, .....Devices and interfaces....Ports.....I see "PXI System(Unidentified)"
Also, I can't see "NI-DAQmx devices"
Does anybode know why it hasn't been recognized?
Vahideh
Message 1 of 8
(5,531 Views)
Your question has nothing to do with LabVIEW. Please provide the version of DAQmx you installed and the os you installed it on.
Message 2 of 8
(5,522 Views)
thanks for your reply, the NI-DAQmx which is already installed is "7.2.0"
Sorry, what do you mean by "os"?
Message 3 of 8
(5,519 Views)
os = operating system
That version of DAQmx is extremely old. Idon't see your device as being supported. It's now important to also provide your version of LabVIEW so someone can know what you have to install.
Message 4 of 8
(5,508 Views)
The version of Labview is 7.1
Message 5 of 8
(5,505 Views)
The latest version of DAQmx that works with LabVIEW 7.1 is version 8.9. This supports the 6221. Download from http://www.ni.com/download/ni-daqmx-8.9/1216/en/. You still have not provided the os but you can check that compatibility yourself.
Message 6 of 8
(5,501 Views)
I've downloaded it, but when I want to install it, ""Unable to open ......\setup.exe"
If I understood correctly it's for 64bit, right?
So, my PC is XP, 32bit...The reason is that?
Message 7 of 8
(5,476 Views)
No, it is for both 32 and 64-bit. Try downloading it again. It sounds like it's corrupted.
Message 8 of 8
(5,474 Views)
