Multifunction DAQ
PXI-6562 Multiple Trigger
HI,
     I am trying to trigger the capture of PXI-6562 with multiple PFIs.   Since I don't have extract channels available, I cannot use pattern trigger.  My idea is to have PFI0 and PFI1 as trigger. So, the DIO card starts capturing the data when PFI0=HI and PFI1 rising edge.
     I am not sure if PXI-6562 is able to do that. I just want to avoid building any extra hardware.
Thanks!
Andy
(3,807 Views)
Accepted by topic author kkwong
Hi Andy,
Unfortunately, the PXI-6562 does not support combination triggering for acquisition from the PFI lines as you are describing.  A pattern match trigger can accomplish this, but only if using a combination of the DIO lines.  Otherwise, for generation, you could possibly implement this with two separate script triggers and a condition statement.  For you application, I would recommend using a simple gate circuit to let the trigger through when the other line is high.  An AND gate would also work.
Let me know if this helps, good luck!
Brian G.
(3,800 Views)
