07-02-2008 11:35 AM
07-03-2008 05:53 AM
07-03-2008 07:26 AM
thanks for the quick reply, the examples was the first place I looked, I was also searching the LabVIEW palette for daqmx. I figure I'm using niHSDIO VIs with the 6561, which are a subset of DAQmx VIs ?. I suspect I don't have the correct items installed to start development. I opted for factory installation service, so assumed the correct components would be installed to match the 6561 cards (and 6123 cards). Attached are screen dumps of the examples directory structure and of MAX software components.
Can you advise on the steps required to determine if I have the correct components installed ?
07-03-2008 07:38 AM
i've found the examples under "modular instruments", discovered the "limit search to hardware" tickbox.
How do I check that LabVIEW has the all VIs installed for 6561 and 6123 cards ?
07-03-2008 08:10 AM
07-03-2008 09:24 AM
07-03-2008 10:53 AM - edited 07-03-2008 10:55 AM
07-03-2008 11:29 AM
07-04-2008 03:31 AM
07-04-2008 03:34 AM
