Multifunction DAQ
PXI-6254 external start trigger (Error -200452)
I have a PXI-6254 that I need to trigger with an external signal so it is synchronised with another device, however whichever source I tell it to use as a trigger (any PFI, PXI_Trig or the PXI_Star line), LabVIEW tells me "Error -200452 ... Specified property is not supported by the device or is not applicable to the task." As an example, I'm trying to do a digital output using the "Write Dig Chan-Int Clk-Dig Start.vi" example.
Is it really the case that this device can't be triggered with an external signal? The manual for this device (http://www.ni.com/pdf/manuals/371291h.pdf) implies that it can be triggered externally, and if it can, what am I doing wrong?
Cheers,
Simon Coop
(3,739 Views)
Accepted by topic author simocop
Hello Simon,
The error you are running into as well as the solution is summarized by the following section in the M Series User Manual page 6-3.
Izzy O.
(3,721 Views)
Hi Izzy,
Thanks for your response.
I would just like to point out then that the 625x specifications manual I referred to (http://www.ni.com/pdf/manuals/371291h.pdf) is wrong. On page 9 under "External Digital Triggers" it says "Source: any PFI, RTSI, PXI_TRIG, PXI_STAR." It then says that these are valid triggers for the digital and analogue input and output sample clocks.
(3,704 Views)
