07-19-2007 02:58 PM
I am new to DAQ and need some help. I am planning on attending NI DAQ training in the future but that will not be soon enough.
I currently have a Labview program working to monitor 8 sensors (2 load cells, 3 accelerometers, LVDT, strain gauge and a 9 volt trigger I use to trigger the start of my program). I have them attached to the SCXI-1314 which is mounted to a SCXI-1520 that resides in a SCXI-1000 chassis. The chassis is connected to a PXI-6250. So far I have only used the single 6250 because I only have 8 sensors to monitor.
I have received a new requirement to add 2 more sensors to the system and don’t understand how to get them to start gathering data simultaneously.
I have attached the 2 new sensors to the second SCXI-1314 and have the SCXI-1000 chassis attached to both of the PXI-6250 cards now allowing me to monitor up to 16 channels but I can’t figure out how to get both of the 6250’s to read data.
I have tried numerous examples to try and get the cards to both read simultaneously and read some of the tutorials, but to no avail. When I input all of the pertinent information into the examples and then run the example I never see any sensor data. It seems like I am not creating a trigger to activate the 6250’s to start taking data.
Any assistance in this matter would be greatly appreciated. I am new at DAQ but I am familiar with Labview and MAX.
07-20-2007 04:08 PM
07-20-2007 08:31 PM
07-23-2007 08:59 PM - edited 07-23-2007 08:59 PM
Message Edited by Matthew W on 07-23-2007 09:00 PM
07-24-2007 09:31 AM
Matthew W,
I ran the Cont Acq&Graph Voltage-Int Clk.vi and configured the Physical Channels as such: SC1Mod1/ai0, SC1Mod2/ai0 and received this error:
200558 occurred at DAQmx Start Task.vi
One task cannot contain multiple inedpendent devices
Create one task for each independent device.
Device: PXISlot11
Device: PXISlot10
Task Name:_unnamedTask<0>
I am running NI-DAQmx Device Driver 8.0.0f0.
Thanks for you help.
Have a nice day.
Robin
07-25-2007 10:02 AM - edited 07-25-2007 10:02 AM
Message Edited by Matthew W on 07-25-2007 10:02 AM
07-25-2007 03:31 PM
It looks like this work fine standalone. Timing looks good also.
I will insert it into my program and see then what the timing looks like.
So-far-so-good.
Robin
