Multifunction DAQ
PXI 6221 digital waveform output
Im trying to output a digital waveform to one digital output of my PXI 6221 DAQ.
This is the block diagram : block diagram.PNG
This is the front panel
As you can see, the digital waveform outputs to the graph like it should.
But to DO 7, it seems to  always writes the last bit of the binary string (in this case 0).
Also, I want this waveform to have a sample frequency using the internal counters.
How do I do this?
Thank you
Message 1 of 12
(4,921 Views)
I've put DO7 on an osciloscope with triggering mode.
This is wat I got:
It seems to output at 1MHz. Its this frequency I want to change.
How do I do this?
Message 2 of 12
(4,915 Views)
You could change your sample rate.  Use the DAQmx Timing VI.
GCentral
Message 3 of 12
(4,908 Views)
M Series devices don't have a dedicated timing engine for digital I/O, so you'll need to route the clock from somewhere else.  The most common solution is probably to use a counter, as in this example.
Best Regards,
John Passiak
Message 4 of 12
(4,902 Views)
I'm using LV 7.1 and I can't find some VI's (device prefix).
Is there any other way to get a counter to be the source of the sample clock?
Message 5 of 12
(4,887 Views)
Hello kev91,
Here you can find the missing VI:
http://digital.ni.com/public.nsf/allkb/9D58153D1B5E5B66862574C8006A30FB?OpenDocument
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 6 of 12
(4,878 Views)
Ok thank you, I've managed to get it working thank you :).
Is it possible to use outputs synchronous?
This is what I already have, but it outputs an error:
Message 7 of 12
(4,872 Views)
The bottom of your screenshot is cut off, but it looks like you are trying to run two different tasks on the same device.  You may only have 1 buffered digital output task per device (but that task may include multiple lines).  Furthermore, only lines on port 0 of your M Series support buffered digital output (I can't see which lines you have selected from the screenshot).
Best Regards,
John Passiak
Message 8 of 12
(4,859 Views)
The bottom is basicly the,same as the middle one.
This is what I want to achieve:
I want one DO to output a clock signal for some time and another DO to go high every 200th clock signal. It needs to get high when the 200 clock signal just had its negative edge and needs to be low when the next clockpulse is high.
Message 9 of 12
(4,853 Views)
Hello Kev,
Is it possible to take multiple screenshots so that we can have an overview of what happens in the complete design?
Kind Regards,
Message 10 of 12
(4,847 Views)
