Multifunction DAQ
PCM-16AI64SS
I got PMC- 16AI64SS DAQ from General Standards. I need to write a VI that inputs # of ch,Gain for each ch, sample rate, acq, time and output an array of ch vs. samples. I someone has answers please let me know or if there is a VI already written please send it to me.
(2,843 Views)
You manufacturer should have provided you with some drivers so that you can interface your board in LabVIEW. Sometimes these drivers come with example programs that you can use as reference for your application. If you would have a National Instruments board, I would be able to provide you with the example you want. This example uses the NI-DAQmx drivers, which can interface with an NI board only.
Hope this helps.
LA
(2,836 Views)
