Multifunction DAQ
PCIX compatibility
does e-series multifunc. DAQ cards work with the PCIX BUS? I think the PCIX bus is a 5V or 10V bus used on some server motherboards, but i
'm not sure. i could check a card to see if the slots match up but i would have to remove it and the cards are all being used right now.
thanks.
(2,722 Views)
To know for sure if your board will work in a PCI-X slot, you would need to know the board model and the revision. You can also tell by looking at the PCI connector to see if there is a slit in it. I think that this Knowledgebase will help to answer your question:
http://digital.ni.com/public.nsf/websearch/27BC5D80CDDD629486256BEB006A57F0?OpenDocument
Erin
(2,722 Views)
