Multifunction DAQ
PCI6110E Input Range no > then +/- 10V
I have problems on my application to read a voltage greater then 10Vs.
I run the test panel for the card and it works fine, seems like the default
is
set to +/- 10V. Does anybody know what functions are being called in
the test panel that overwrite the default settings? Thank you.
(4,306 Views)
just to anybody that might run into same prob. I had a bad achannel and even
with the gain setup correctly won't read > then 10v. Use a different channel
and worked fine.
(4,306 Views)
