Multifunction DAQ
PCI cards with more A/O?
Does NI hace PCI based DAQs with more than 2 analog outputs? (say 😎 I couldn't find any on the web site.
(2,778 Views)
Yes PCI 6713 should fit your spec
(2,776 Views)
For selection, here is a link to some of our Analog Output Devices.  Just click the links on the left to find a board that meets your needs.
-Alan A.
(2,757 Views)
Thanks. There seem to be several afterall. I guess I must have been searching under Multifunction DAQ.
Is there any choice that is known to be well suited if low noise output is desired?
(2,754 Views)
The specs will vary a little from board to board, so your choice will probably depend on how much noise you will be willing to tolerate.  You might want to check out this link.  You can take a look at the specs of different boards and compare.  Enjoy.  FYI - I got to that link by clicking the "Manuals" link under Resources on one of the product pages for an AO board.
-Alan A.
Message Edited by Alan A. on 11-23-2005 01:22 PM
(2,748 Views)
