Is it true that PCI-MIO E series can only measure different voltage? If I want to measure currents, I need to connect a small resistor and measure the voltage drop? I guess this is the only way to measure currents, right?
> Hi, > > Is it true that PCI-MIO E series can only measure different voltage? If > I want to measure currents, I need to connect a small resistor and measure > the voltage drop? I guess this is the only way to measure currents, right? > > Thanks!
