Multifunction DAQ
PCI 6722 Analog Output Card
Dear SIr,
I was told by local distributor that PCI-6722 Static & Waveform Analog Output board has become obsolete. The same got confirmed from Websites.
The local supplier suggested PCIe-6738 board which is high number of outputs etc, where as PCI-6722 has 8 Analog Ouput with compatible BNC-2110 Panel.
Is there any equivalent successor for the PCI-6722 board ?. PCI Express Version also will do.
Thanks in Advance
Nageswara Rao
(1,244 Views)
Any specific reason why you would not want to go with a latest replacement with extra features?
Santhosh
Soliton Technologies
(1,224 Views)
Dear Sir,
Thank you for responding.
I understand that PCIe-6738 has many Analog Output channels and there is no compatible BNC Panel. Our system requires a BNC Panel, else I have to modify the hardware setup. In fact, I need only three analog outputs.
Nageswara Rao
(1,210 Views)
In that case, you can still buy a PCI 6722 from third-party vendors like Electrorent, Apexwaves and Artisan - these vendors deal with obsolete NI hardware
https://www.artisantg.com/TestMeasurement/55206-2/National-Instruments-PCI-6722-Static-and-Waveform-...
https://www.apexwaves.com/modular-systems/national-instruments/analog-output-devices/Pci-6722
Santhosh
(1,203 Views)
