Hi, I have two Encoders. I need to do the 'Buffered Position Measurement'using PCI-6602. And both encoder positions should be read simultaneously. I wonder if I could have some example VIs to easily start. Thank you for your kind consideration.
I am doing something very similar. There are a few examples available from the Knowledge base. There is an example called "Measured Buffered Position (NI-TIO).zip" available. All you need to do is choose the selected gate signal. You can use this as a start but it will need some serious development. Otherwise there is a serious lack of info on how to do similar things to this.. come on Ni help us out!
