Hi Jan,
It is possible to program this device to use interrupts using the DAQmx driver. I'm not sure which programming language you are using, but there is a relevant example in C that installs with DAQmx. By default, it will install to the following location:
C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure Voltage\Cont Acq-Int Clk
If you specifically want to do register level programming, I suggest that you post on the
Driver Developer Kit (DDK) board. Thanks,
Message Edited by Luke G on 05-29-2007 01:45 PM
Luke
