Multifunction DAQ
PCI-6225
I have to sample 80 signals. The PCI-6225 is said to manage this at 250kS/s.
- But is 250kS/s the maximum frequency reached when only 1 channel is used ?
- If yes, what becomes this frequency when all the 80 channels are multiplexed ?
Thanks.
(4,038 Views)
You are correct that 250 kS/s is the total sample rate. For 80 channels, the maximum sample rate is 250000/80=3125 S/s.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(4,030 Views)
Yes I know this. The total (aggregate) amount of S/s is divided by the number of channels to obtain the amount of S/s/channel.
But I was only talking about the total (aggregate) amount of S/s. Is this quantity not reduced too when the multiplexor is running, because of some additional delays (interchannel delay, the interscan delay (1 scan = 1 reading of all channel), settling time, ...) ? Is this quantity not reduced too when increasing the accuracy (the more accurate, the more the settling time too) ?
Thanks.
(4,018 Views)
That kind of information would be in the specifications. You can download the specifications document here:
http://digital.ni.com/manuals.nsf/websearch/D46066EF4005E18B862570190078B514?OpenDocument&node=132090_US
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
(4,009 Views)
The maximum sampling rate of the PCI-6225 is 250 kS/s regardless of the number of channels scanned.
(3,987 Views)
But because channel scanning is multipled with the same clock, the scan rate is 250kS/s  / # of channels.
Your statement is true for the S series cards, where each channel has a dedicated clock.
(3,977 Views)
