Multifunction DAQ
PCI-6225 not detected with Windows 10
I have several PCI-6225 cards running on Windows 7 PC's. I want to migrate those cards to Windows 10 PC's.
My first attempt was to move one PCI-6225 card into a DELL OptiPlex 7060 that has a PCI slot. I have downloaded and installed with success NI-DAQmx version 21.8. For some reason the NI Device Monitor does not see my PCI-6225 card.
Are the PCI-6225 cards compatible with Windows 10?
(1,492 Views)
I have exactly the same issue with the same card. Were you able to find a solution after all?
My motherboard is an Asus H510m-c with an Intel i5-10400 CPU on Windows 10 64bit. DAQmx driver is version 21.5.
The board is not showing up in MAX, nor in device manager.
(1,210 Views)
Hi Basjong53,
No, I was not able to find a solution so far.
thanks
(1,200 Views)
I have solved it in the mean time. The problem was an MXI-PCIe card on the same motherboard that somehow went into conflict with the PCI board. I moved the MXI card to another slot and the PCI board was recognized.
If you have other PCI(e) boards installed, it may be the problem.
(1,197 Views)
I don't have any other extension cards in this PC. Maybe the PCI slot is not working properly.
The fact that you were able to make a PCI-6225 work with Windows 10 gives me confidence.
I will try to find another Win10 PC with a PCI slot to see if its the case.
thanks
(1,174 Views)
