07-10-2009 08:26 AM
I have moved PCI-6221 card in another, new computer, running under Vista 64-bit. NI DAQmx 8.9 was instelled on this computer. The card is not, however, recognised correctly. In "Device manager", I see (after inserting the PCI-6221) a "SCSI controller.
Do you have an idea what can be wrong?
Thank you.
Jiri
07-10-2009 09:03 AM
Well, I will answer to myself.
The problem was that I have not moved from that computer the PCI-6221 board, but a SCSI Controller board which was also installed there... NI board is working correctly, as always, off course...
Jiri
