Multifunction DAQ
PCI-6115 re-trigger
I have a PCI-6115 card and I'd like to set it up to automatically re-trigger. I'm planing to use Digital Edge external trigger with 5 MHz internal clock. The trigger comes into the card as a 300 Hz signal and for each trigger I want to collect 100 samples.
I tried to use the Start.retriggerable property, nut it is not supported on this card. See the attached example .
Does anybody have any idea ?..
Thanks.
JesusV.
(3,172 Views)
The hardware doesn't natively support retriggering, but there are ways to accomplish it with the counters on your board.  See the following KB: http://digital.ni.com/public.nsf/websearch/82DAECADE90CC56F8625659200675B2A?OpenDocument
Unfortunately, you may run into a few issues with your particular board, see the following forum post:
http://forums.ni.com/ni/board/message?board.id=250&message.id=41450#M41450
Zach Hindes
NI R&D
(3,161 Views)
