Multifunction DAQ
PCI-6071 E cards
I have the PCI-6071E cards and with one of the cards I get the following error when I run the self-test:
"The device is not responding to the selected base address. Would you like to continue?".
If I click yes to continue, I get error message "-10800".
Please help.
Matt
(4,297 Views)
I have the same DAQ card!  I am trying to learn more about it too.
-Scott
(4,281 Views)
Hello Guys,
The following knowledge base should be helpful for this error.
Please feel free to post any further questions.
Faris A
Bueller
(4,270 Views)
I tried those ideas with no avail. Here is the situation that happened. I was collecting data in MED64 Performer software. I have 2 cards connected together for the 64 channel I/O. During an experiment, the lower channels began to respond erratically. I shut down the system, restarted and the board basically quit responding as described above.
Matt
(4,251 Views)
Matt,
I'm sorry that non of those steps worked. At this point, I recommend downloading the DAQ Diagnostic Utility. It's a small download. Once you download it, run it and see what kind of results it will give you.
Please let me know about the results.
Faris A
Bueller
(4,233 Views)
Here are the results from the test:
7/2/2008 12:55:07 PM
Results saved to:  F:\Diagnostic Results2.txt
Selected Device: Dev2
Device Type: PCI-6071E
Serial Number: 1237207
Device Support: (PASS)
NI-DAQmx Version: 8.0 (PASS)
Device Reset: (PASS)
The device was last self-calibrated on: 10/17/2006 3:36:39 PM
Running Calibration ...   FAILED for the following reason:
Error -200545 occurred at DAQmx Self Calibrate.vi
Possible reason(s):
Self-calibration failed.  The self-calibration date has not changed.
Disconnect the device from external signals, as they might introduce noise.  Externally calibrate the device to recalibrate the onboard voltage reference that is used for self-calibration.
-------------------- Testing Counters... --------------------
Testing CTR Buffered Pulse Generation...   (PASS)
Testing CTR Single Pulse Generation...   (PASS)
-------------------- Testing Analog Input... --------------------
Testing AI Ground Reference...   (FAIL)
************ Test FAILED for the following reason ************
Analog Input was not within tolerance for ground reference.  Expected to read: 0.000000  Actually read: -10.000000
Testing AI Voltage Reference...   (FAIL)
Analog Input was not within tolerance for reference voltage.    Expected to read: 5.000000  Actually read: -10.000000
Testing AI Finite Sample Clock...   (FAIL)
Count of sample and convert clock pulses does not match expected number.  Frequency: 20000.00  Samples: 10.00  Channel List: ai0:4
Testing AI Finite Sample Clock Frequency...   (PASS)
-------------------- Testing Analog Output... --------------------
Testing AO Finite Sample Clock...   (PASS)
Testing AO Finite Sample Clock Frequency...   (PASS)
Testing AO Single Point...   (FAIL)
This test failed to output 9.000000 Volts on Dev2/ao0.  The actual value written was -10.000000.
Testing AO Accuracy...   (FAIL)
This test failed to generate a voltage waveform with an error of less than 0.385802 Volts on Dev2/ao0.  The actual average error was 10.000000 Volts.
-------------------- Testing Digital IO... --------------------
Testing DIO Lines...   (PASS)
Testing DIO Ports...   (PASS)
 ----- DIAGNOSTIC TEST COMPLETE -----
Matt
(4,225 Views)
It looks to me that your DAQ device is broke.
Please Contact NI for repair.
Faris A
Bueller
(4,169 Views)
