Multifunction DAQ
PCI-6052E with NIDAQmx 9.2.3 not seen by MAX
I have a PCI-6052E card installed and was using NIDAQmx 8.9 drivers and all worked well. Then I upgraded to version 9.2.3 and now it doesn't show up in MAX anymore.
The card gets properly detected by Windows XP and shows up in the device manager.
I have already tried removing and reinstalling the driver and also uninstalling and reinstalling from the device manager.
Any advice how to get it working again?
Ralf
(3,045 Views)
I completely uninstalled all NI Software and then reinstalled NIDAQmx 9.2.3.
Now MAX sees my DAQ card, but the Test Panel doesn't work.
I had to rename c:\WINNT\system32\nidmfpan.exe.manifest to nidmfpan.exe.manifest.bak to get around that problem.
I thought I post this here in case someone else runs inthe same problem.
Ralf
(3,030 Views)
Suggestions I have found seem to say that a corruption from the install files may have caused this, but nothing conclusive at the moment.
Thanks for posting your solution back to the forum, Kudos for that!
Regards
Richard S
Certified LabVIEW Associate Developer
National Instruments UK&Ireland
(3,017 Views)
