Multifunction DAQ
PCI-5124
I would like to know if the PCI-5124(http://www.ni.com/pdf/manuals/376933b.pdf) can work at its full potential if I use a PCIe to PCI adapter.
Any suggestions on how to use the PCI-5124 on a PCIe would be appreciated!
Many thanks !
(2,483 Views)
Here's an article on using PCIs on PCIe:
PCI to PCIe Adapter for National Instruments Devices - National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019N1YSAU
As mentioned in the article it might work, but NI does not recommend using any adapters as it may cause some issues. So to answer your questions, it is most likely that you will not be able to achieve the full potential while using PCI on PCIe.
Hope that helps.
Kind regards,
Ruta
(2,436 Views)
Thank you very much Ruta!
Kind Regards,
Gianni
(2,432 Views)
